HTF do you get the clutch peddle on??
I've stripped down under the steering wheel to give me access but it's fouling on a loom. I've tried it all ways and can't get it to fit on to the clutch booster :cursing:
I can't see how the loom can be moved, so what am I doing wrong?
Help it's really doing my head in:helpsmilie:
With great difficulty in an automatic.............:oops:
I'm converting it ya doofus :lol: :tt2:
you can trim the little offending tab down to just above the bolt hole.(ive done one last week).also i fitted the pedal with booster attached and found it easier..lee
sounds like a plan, cheers Lee
lol Steams, I thought you would be, but thought you may like a bit of a laugh as seen as it's getting to you a bit......:rofl::tt2:
I always get a laugh from you matey :lol: cheers. :thumbup:
Who gave you my photo then........:rofl:
if its still difficult to to locate cos of the loom ya can always take out the clocks to get to it properly
rich
loosen the booster off a bit so that it can angle down and then slide the peddle on. I had the same problem as you when i changed my booster. just couldn't quite clear the loom so thats how i did it.
Thanks for all the ideas, I'll get the bugger on tomorrow. So far, removing a gearbox has been bleedin quicker! lol
Got it on today what a PITA. It was just as bleeding awkward as fitting the drivers side steering rack bush while the car is sitting on ramps.
Have you got a sore shoulder? I know i definately got one! :D
no but me back is aching.lol
yer keep pedal and booster loose just slightly nutted up then put it in .
yep, that's what I did. Just wish I'd worked it out a bit sooner and saved myself a lot of swearing. lol
