clutch problem
my car is going to see jeff in may to sort the clutch out. I was just wondering if it could be a simple fix that I could do. the clutch started to slip in 3rd 4rd5rd on checking the master cylinder found it to be leaking. so I have replaced it with a new one and it was still slipping till I adjusted it. then I went out for a drive was out for about 4hrs then it started to slip again so it was pked up for the night and the next morn I was driving it to my lock up when I took it out of 2nd it would not go into 3rd or any gear until the engine was turned off and then I could select a gear so I started it up in 2 nd and limped to the lock up I have bleed the system again but no luck
