MOT time with top end rattle
It will pass with that but could be low oil level so check that first. Then it would be a case of oil and filter change and then use Wynn oil treatment if needed. I had the same when i bought the black shorty and a good run out cured it :)
100% Sticky lifter. no question about it. you can buy some lifter oil from halford for about £5. stick it in and 10min later it will be 100% new again.
i did mine 2 days ago. Its because the cars hasnt been run for a long time and the oil has drained out. nice and easy :)
Great stuff, i'll do this in the morning !
Hello mate, its because all of the oil has gone into the sump because it hasn't been driven in a while, take it on a long drive and it will be fine! Mine does it all the time, i think the term is stickey lifters, it will be fine mate :)
Had a pre MOT panic again there, less than an hour to go and my brother who's
taking the zed for its MOT told me that the zed never had any rear reg plate lights.
When we changed the bumper the old lights were rotted with rust but luckily i ran
home and found another set lying in my hut.
Only 20 minutes and the test begins.
Fingers crossed !
