Restricted imports
Hi, are all Jap imports restricted to 112mph, and how were the cars restricted. The speedo in my car only goes to 120mph, yet i,ve seen other N/A models with 180mph.
Yes all are restricted (unless been de-restricted of course!)
And your dial face has been changed to sort of read Mph!:wink:
mate mines only goes to 110 not tried it yet but i think the restrictor is still theyr
im thinking once i upgrade a few parts going for a jim wolf chip
How do you de-restrict an imported car, out of interest.
a kmh to mph converter will de-restrict it . pretty sure a set of uk clocks will do the job too .
To do it right,change the chip and clocks.:whistling:
Ah, thanks, i thought it might be something a bit more complicated than just removing that plastic block from under the gas pedal:whistling:
The jap clocks even with a convertor the odometer will read in kph. UK clocks will read in miles and get rid of the restriction, but also at a later date get the ECU chipped, mapped for rev limit restriction set highter, fuelling etc.
I didnt realise that, I thought the converter did the odo too.
the convertor technically doesn't remove the limit, it just raises it (I think) to whatever 112 MPH is in KPH...
So if i buy a set of clocks off a UK spec scrapper and fit them this will de-restrict my car ? What is it a chip in the clock or something.
The convertor just tricks the ECU into thinking its going slower, so basically a resistor. It can also effect the power steering.
Agree with the above, Converters are not a good idea on cars with 4 wheel steeing as if you swerve at 80mph the hicas will react to deal with a swerve at 80kmph (50mph).
It's already restricted to 112mph (or 180km/h) so the convertor makes the car think it's still doing km/h when it's actually miles. If that makes sense - so the new limit would be 180mph
I believe so - but UK spec clocks are getting pretty rare now, so good luck in your hunt!
Yup, what they said - so it's always best to have it done properly so that car knows exactly how fast it's really going!
Richard:cool3:
Thanks for the info everyone, think i'll leave things well alone, wont be often i'll be doing over 112 mph, think i'll just make it a bit quicker from 0 to 112. First step taken today, fitted a couple of K N filters, not a huge difference in performance but she does fly. Exhaust next i think. I watched wheeler dealer the other night and they were doing up a scoobie wrx, they fitted a K N filter and a performance exhaust and the mods made the performance worse then standard, but alot better after a new chip and a rolling road tune up. Can fitting an after market performance exhaust spoil the performance on my ZX ? Most cars seem to have them.
think only if theyrbadly made and the pipe diameter is to small..restricts the exhaust gasses causing to much back pressure bad in an N/A
I have heard something like a bit of back pressure is better for an N/A but not a turbo.....
.......so a massive exhaust on a non-turbo car will actually inhibit performance; whereas on a turbo the bigger and more free flowing, the better....
Richard:sweatdrop:
