help needed please
hello and can some one pls help i got a water leek the other week from the top rad hose fixed that but lost a lot of water now fixed it but now the enj temp gauge on the dash never goes above the cold to 1/4 mark have i put to much colent in or do you think pos thermastate isu
manny thanks
mark
Sounds like a thermostat sticking open buddy. It is a very easy and cheap fix, worth a try matey.
Alz.
may sound daft, but after fixing the leak. did you top up the system, by just filling th rad to top.? if so
Or did you wait till it was warm, with bleed valve and rad cap off, and make sure heaters were set to hot,and car jacked up as much as poss at front
you may have an air lock.
