02 Sensor replacement and improvement
Just ordered new 02's from Zcentre, as im gonna go through the process of elimination.
Now has anyone had theres changed and noticed an improvement in fuel range/ economy? if so how much?
and secondly is this a DIY or specialist job to replace them?
...and secondly is this a DIY or specialist job to replace them?
I changed mine on my V6 Probe, the problem was more about getting to the sensor and getting a spanner on, changing of the sensor is the easy bit. Universal ones need to be wired in, you have a positive, negative and sometimes a heater wire which warms the plug beofre the engine and exhaust warms it.
Though I do remember needing a 22mm ring spanner that I had to cut in half as there wasnt room to get the whole length in.
The sensors (or at least one of them) on the Zed look a lot easier to get at, so hopefully pie on the Zed... :)
Mine were on the verge of being impossible to get out. I broke 2 crows feet spanner to get them out and there a pig to get to.
as for mpg i noticed no differance. good luck :lol:
no difference?????? damm it .
anyone else done theirs and noticed any difference, in fuel usage/ tank range.
I run mine with the O2 sensors disconnected, so it runs on a means setting. I dont notice any difference in fuel usage, it always drinks it lol.
