Clear Safety boost
Is there any other way to reset the safety boost fault code from the ECU apart from Conzult?
I've bypassed the Det sensor just need the code clearing, but the battery off for a while method isn't working :/
Ahh forgot Lee lol. Need to come a run down this week at some point if that's cool mate?
Need to get a look at your neways since your changes :)
Code34 (det sensor) is reset when you switch of the ignition. If the car is still in safety mode then the fault is still there.
you'll be better bypassing the dett. sensor from the ECU rather than the engine bay, as usually the fault isn't the sensor, but the wiring inbetween the sensor and ECU... I forget which pins you need to short, but I know the info is on here somewhere mate....
According to this you have to reset the ECU ...
