cant seem to find the other connection for this! it comes out from the ignition key barrel as you can see in the pics anyone steer me in the right direction please :detective:
dan.:confused1:
isn't one something to do with the auto gearstick? Sure it puts a lock on the shift or something like that
not sure will have another dig around but cant seem to find the other end! dont remember disconnecting it!lol
dan.:blush:
anyone got any other ideas what it does or have a look at your ignition to see how it fits? :wacko:
dan.:surrender:
I am taking the ignition apart today so will post any findings for you. I have a manual so it may not be the same if you have an auto.
Allan
Allan
thanks that would be great, it is an auto but any help would be much appreciated, i dont remember disconnecting it when i took the dash out thats the strange thing!
dan.:helpsmilie:
I've an auto too, it's in the work shop at the moment but
will take some pics of the ignition later to compare.
that would be great thanks to you both.:duffer:
dan.:thumbup:
Thae cables you have a problem with are not on the manual, so I cant help you with you any further, sorry
Allan
Allan
thanks for looking.:thumbup:
dan.:sweatdrop:
just a guess from looking at it, could it be from the auto shifter, as I'm sure when mine was an auto, you couldn't take the key out of the barrel unless it was in park, it could well go from the shifter to the solenoid on the barrell, only an educated guess tho matey...
ok thanks, will check the key idea, once jaikai has had a look over his perhaps can find where its meant to plug in dont want to pull it all out again!:hammer:
dan.:detective:
I have two here, one is to go in the indicator stalk on the Jspec and this controls those kerb lights when indicating, the other though - haven't got a clue :confused1:
sorted!:clap: thanks for steering me in the right direction, once i laid the connector out along the steering rack after some digging around i found the other half tucked away, and you are right Tudor the key could come out in any position.
dan.:thumbup1:
