how do i kill the airel
its ugly i dont do radio and id like it to stay down rather than popping up every time i turn the key. so where the wire to disconnect. or fuse to pull.
disconnect the wire for the aerial from your headunit :) think the fuse is in driver footwell
there should be a setting on your head unit that only allows it to pop up only when the radio is on :)
To disable it totally, without going the fuse route, eother take the rear panel out and pull the plug or the easier option unplug from the head unit and disconnect the blue wire (aerial feed)
will that be in english also mr groover? :D :D cheers guys, little five minute job for next week.
no that's in Japanese :chinese: :lol:
Seriously though, instead of totally disconnecting it and if your headunit doesn't have the option, you could simply fit a switch into the power line, then you can control it; switch it on should you need it.
the route that takes 20 seconds and stops it from looming over the rear of my car like some sort of chips throw back is fine lol
A bent coat hanger on the wing will add that touch of class :death:
i think il pull the headunit and disable it from there as suggested keeps it simple quick and tidy
lol sounds an ideal option lol it extends about 2 or three sections dunno how big its supposed to be.
havent seen the noisey beast about recently gaz. not since when i saw you at the petrol station the other week. let me know about the ariel lol if the bodywork part comes away ie so i end up with a red non working one and you end up with a black working one sounds like a plan. anyways im off to bed, pm me when you decide. im away this weekend but il be about all week.
