two mafs
is there any way to use two mafs and seperate air filters?
iv got the hks air filter just now but im kinda woried about the clearance the filter is sitting about 2" ahead of the air ducts ..is there any way to get rid of the t piece and use two MAFS with two air filter?
just a thought
No point unless running serious power. There are some threads on the subject, if you do a search
howd you go about it though
do you need to splice the wires together or can they be run sepretly
i know iv only got n/a but after work comences again in the new year im looking to tune like f00k i know it not eco or anything but itll be a bit different
People run a dummy maf that isnt plugged in as you only need the one reading
would that not run one throttle wierd coz both would need the same air/fuel reading to run equaly
my thinking is if youve got two seperate air filers but only one side reading the airflow would the side with the dummy maf not make it run lean/rich
nope both filters will be taking in the same amount of air. The ecu wont inject different amounts of fuel of different banks of the engine it would be consistent as it would still believe it was running on standard airbox. Allthough with filter upgrade lke any mods it is best to get the ecu tuned to run correctly with the mods
ok i thought that the maf took an air flow reading then the ecu split it between both banks..never tred tuning a V engine before im used to 4 bangers
The throttle operates both throttle bodies equally with the throttle position sensor on one of the throttle bodies so all the information is there for the ecu
thinking now im gona sell my hks and get two cones coz i dont really want to pay £££ for another hks mushroom
i know i seen it earlier but im skint till after the new year and if got heater matrix to sort out would have been ideal though if i had cash the now
i thought about building a wee heat shielded cold air box that encloses the air filters coupled with two fog replacment ducts with pipes feeding the air into the C.A.B
Avoid the dual pop at all costs, they are nothing but problems.
how come?
Since the Selin dual maf translator has been on the market, most of the common dual pop/intake problems are a thing of the past...it requires 2 AFM's though.
http://www.selindesign.net/electronics.html
with 1 AFM and 1 dummy it's still a disaster ;)
