Swapping oil presure senders
Looking to swap two oil pressure senders that are on my zeds,
one is an after market sender for my digital guage and the other
is stock, whats the best way to do this ?
I'm thinking find a bolt with the same thread size or stick a small cork
up the whole when i pull the first sender off.
Any better ideas ?
Just drain the oil and do a filter and oil change. i am sure your Zed will thank you for the oil change.
you wont get much oil out of the lines if you're just taking the senders off.
it will drip out at a slow rate, you probably won't even notice a change on the dip stick
