I want cruise control...
I have a 93 SWB TT but it doesnt have cruise control like my other's had.
Can i fit the parts nessesary to give me cruise?
James
After market kit would be the easiest way such as the link below, can be made to appear very similar to stock too.
http://www.ultimatedesign.co.uk
Jeff TT
Edited by JeffTT
You can have mine if you can take it off my car and leave my car running the same! Is there much weight to be saved by losing it?
can i actually fit Z cruise control to a car not fitted with it from factory though and i will need a list of parts if so..
Thanks Jeff but link no work..
cheers
James
Link fixed
Jeff
yes, there is a write up somewhere, saw a link to it posted in the last few months
its quite a lot of work though
fit actuator and cable under bonnet
fit switches to clutch and brake pedal (possibly including welding extra plate to push switches) or replace clutch and brake pedals
run wiring loom from near fuse box to actuator under bonnet and splice in
fit ecu in passenger footwell, (possibly run wiring loom)
fit cruise cotrol steering wheel or cruise control stalk (rocking horse poo or £few hundred new)
[sIGPIC][/sIGPIC]
i dont mind a challenge but if only a handfull of people have completed such challenge then i may have to settle for the aftermarket kit Jeff suggests. Thanks all.
I dont have cruise in my 94 slicky James :sad:
Not bothering me but am reading with interest any posts in this thread.
Sounds way too much work though :ohmy: If I was you I would just forget about it, just get a pod with a cruise control switch instead of the blank, so it then looks like you do have it :whistling: :whistling:
Most of the Cruse control retrofit is straight forward. The only big issue is to do with wether or not the car has the same interior wiring loom as a cruse control equipped Z, becuase havign to replace the Interior wireing loom would be a big job.
Im not sure wether it does or not.
the write up i read of someone who had done it suggested that the loom to the cruise ecu, pedals and controls was there and that all that was missing was the loom to the actuator under the bonnet, and that was just 4 wires that they spliced in near the footwell fuse box.
i think it was a us zed so whether that is true for all zeds i have no idea
[sIGPIC][/sIGPIC]
