Daft Silicon pipe question
I've got the silicon tube pack from the Zcentre, I know it can't be used for petrol or oil but can I use it for the plenum water bypass?
Or do I need some coolant hose?
Dave
Cheers folks, sort of confirmed what I was thinking.
I did my bypass using silicon and never had a problem !
8 mm id silicone hose is fine for coolant bypass as other peeps have said.
bugger, I've bought some 8mm fuel hose for it now :(
Don't use the 8mm silicone for fuel or oil :eek: It hasn't got a high enough pressure rating and is not compatiable with fuel anyway, you can get a fluro lined version for petrol but better just sticking to proper fuel hose.
He's using it for coolant^ I personally wouldn't unless it was REALLY hard to get hold of some proper coolant piping just for peace of mind.
