thermostat
Right i have my thermostat from my car in front of me, now i know it should be fully closed when cold, but its not, but i have a niggly feeling about it so just would like someone to confirm it lol
Fully closed = good
Almost closed but not quite = bad
Thanks, for some reason i questioned my self about it, even knowing all too well that its closed. even scoured over jeffTTs threads and saw a few closed just to make sure but still that niggly feeling. i suppose I'm going to get my arm chewed off for a Genuine Nissan part lol
just pricing it all up at the moment, timing belt, timing belt tensioner, should i replace the idler pulleys?
may as well do that while the front of the engine is apart for the water pump.
so after all those pm's a while ago, i was right. told you it was a possible thermo ;)
yeah but even you admit its a bit strange going for a hours drive and finding the rad cold?
Save yourself some money and get from MJP instead.
You can check the idler pulleys for noise, resitance, play. If they do anything other than spin smoothly and quitely then replace them.
