Conzult Screen Shots - For Diagnosis
- Replies 30
- Views 1.8k
- Created
- Last Reply
oobumblebeeoo 16 posts
JeffTT 6 posts
Smithy 1 post
TonyB 1 post
Hi guys,
Managed to get a consult reader and the free software.
Not sure how to use it really, but hooked it up to me car, got the screen shots of the car idle on cold start idle, warm idle and then warm idle after adjusting the idle time... it said it was out and made the car idle way past the green ok bar on the software, so adjusted it accordingly, then done a screen rip after it was done.......
Can someone help and tell me if my car is ill?
I also noted my o2 reading was moving quite a bit on warm idle instead of looking stable. Is this normal?
Here are the pics with info for diagnosis :-
IDLE COLD AFTER START (AND BEFORE IDLE SET WITH IDLE BUTTON)
WARM IDLE - BEFORE IDLE ADJUST
WARM IDLE - AFTER IDLE ADJUST
WARM IDLE - AFTER IDLE ADJUST - PREVIEW; SEEMS IT DOES NOT WANT TO IDLE INTO THE GREEN EVEN THOUGH THE SCREW HAS BEEN TURNED A LOT, DIDN'T WANT TO KEEP ALTERING, SO LEFT IT AT THIS... RIGHT OR WRONG THING TO DO??
GENERAL INFO WINDOW
TROUBLE CODES (REPLACED THIS SENSOR A WEEK AGO, SO SHOULD I IGNORE THIS?
