Hi guys, im sure you know the thing i mean, the gauge holder from z center.
Does anyone know the dimensions of it?
is it something like 200 by 50, by 3 thick?
Mark
Just remember the guage mount from z centre is recessed!
The gauges actually sit behind the holder, there is a 2mm lip
Round the plate that fits from behind the centre console then
Another plate fits behind the gauges!
The holes you see in the plate are smaller than 52mm and
Are only ment to see the gauges through as below ;
Face plate. ---/..../------/..../---
Guages. :::: ::::
Back plate. /..../-------/..../
That's a side on view !!! (if it shows right)
Yeah i got a din blank to cover up the hole for now and it doesn't go right into the slot because the dash trim is in the way.
I see, i was going to cut the holes out to the bulk of the size (52mm)
and have the rim of the gauges on the outer surface.
I can get it laser cut at uni for cheap ;)
You'll have a tough time fitting Guages in there unless you do the same design
as it's exactly 52mm in height! That leaves no room for the guage bezel, that's
Why it's fitted from behind the centre console as from behind there's lots more
room.
On mine I glued the plate to the centre console and fitted Guages inside then
pushed full console part including Guages into place !
Yeah ill create the geometry in cad, give it a very slight tolerance of .25mm or something, trial and error with mdf first i think.
Even if i create some complicated geometry i can test it on the computer first.
I wanted the outer bezel of the gauges on the outside of the plate. I havn't decided what gauges im going for yet. wont be anything fancy, as long as it does the job
Yeah thats what im counting on really, I was just gonna dob a bit of silicone behind the bezel or some ptfe tape near the rim.
i made my own, but i've got the bezel if ya like, touchin the front of the surround, i had some black vinyl left so i wrapped the outside of the gauges with it, looks tasty...
IMAG0139.jpg?t=1285153152
IMAG0145.jpg?t=1285153152
IMAG0140.jpg?t=1285153152
Thats the idea i had tudor, maybe cutting a more elipsed hole to fit them in at an angle.
Did you make that piece yourself joely p? Looks like nice quality.
I should have explained, im a poor student, and ive spent all my money buying and insuring the car ;)
Plus i think it adds a personal touch if i made it, i was thinking of wraping it in zebra print vinyl anyway, i assume its not to most of the forum members tastes :D
'Optic Zebra Pony Skin Velboa' what ponies look like that, plus its outta stock.
:lol: the funny thing is i live walking distance from whipsnade zoo
