Hi guys'gals.
anybody with a 99spec front bumper...........have you had any trouble trying to fit it? did you have to remove anything to fit it?
Just i got mines sprayed etc and went to fit it and its quite a struggle to get it on. So had to bolt it on with a couple bolts and leave it the now until im home from work.
Just wondering as it is abit of a struggle and i was pulling and pushing and lifting etc etc............
anyone?
Craig
Does you car havE standard or aftermarket intercoolers? Mine required a bit of modification because of its big ass front mount. Other than that it went on oka although it was already fitted when I got th car it only came of during the respray.
As above - fine apart from the IC ducting - I cut the inner corners to open them up a little. All fits fine apart from that :)
Yep, same here... the intercooler ducts will need modifying a little (or fit proper 99 spec ones) and i found that the polystyrene was a bit tight!
i removed the polystrene completely, is this a good idea?
I assume it must be my ducts that ar stopping me getting it on then, i have standard intercoolers.
Is it a bad idea to remove the ducts or should i just sand it back a cm or so?
Just when i was trying to fit it i thought it should go straight on as people have said.......not with a struggle.lol.
hi mate you have to shave the to[p and bottom lips off the reinforcer and relocate the little brackets on the bottom of it to the side a bit more for the open mouth part should slip straight on then hth
i had to shave some bits because of my front mount intercooler but otherwise it went straight on! did you not try it for fitment before you had it sprayed?
dan.:biggrin:
Can you buy 99 spec bumpers new or are they a rare 2nd hand find only ?
Yes they are available new, hard to find 2nd hand.
