engine problem solved, well...almost
had an issue with the car at the beginning of the week where it felt like it was running on 5 and a half cylinders and I suspected a faulty injector. Turned out injector No1 was on the blink. Changed the injector yesterday and it seems to have cured the problem, at least to 90%
The problem is that I still have a slight hesitation and the feeling it´´s running on 5 and 3 quarter cylinders on idle and pulling away from the traffic lights. Onnce the car is moving and above 1500 rmp it drives fine.
I measured all the injectors and they all read between 11.9 and 12.1 on resistance so they should be okay.
does anyone have any idea what could be causing this ?
Maz
Good point mate, I´ve got new coil pack connectors but haven´t checked the coil packs themselves. Is there a way of checking the coil packs or is it a matter of using a spare one and changing them one by one until you find out whether or not is was a coil pack ?
Maz
I´´m not sure that would work mate, the problem isn´t that drastic like losing a whole cylinder, which you would notice right away. It´s kind of hard to describe. when an injector goes the car sounds and drives like a tractor, this feels the same on idle and when pulling away but just nowhere near as bad...like 10% of that sound and feeling of running on 5 cylinders. Hardly noticable on idle from listening to it from the outside, if you didn´t know the car you might even think it always idles that way...but there´s a slight shaking and uneven idle
:confused1:
:confused1:
have you done a compression test?
haven´t done a compression test yet...was hoping I didn´t have to go down that road, but I guess I will have to eventually.
I think I´ll recheck everything over again, injectors, coil packs, CAS. TPS etc and see if I come up with anything.
Cheers Joel
SORTED!
Sometimes I´m just dump :( Should have noticed that....checked all the injector connectors and one of them wasn´t on properly , pushed it all the way on and the engine is running 100% again......sorry for wasting your time there guys.
Maz
