Water pump removal...
Can't use search on my iPhone, Iv got the rad, fan, pipework and half the cam cover off, is there a guide on here? I'm unsure as to what else needs to come off, does the thermostat housing need to come off too?
No mate the water pump is seperate from the 2 pipes, Remove the 6x 12mm bolts and it will come off, remember its got gasket sealer and not a gasket so will need a pry or little clout.
Edited by groover
you will need to take off the bottom half of the cam cover to. I think the crank pully has to come off to?
Tw@t of a job. i couldnt get the crank pully off so i ended up cutting the bottom cover lol!!
