oil pressure on n/a
hi just checking what oil pressure most peoples zed's run, mines a n/a, on the gauge on the dash, from cold mine reads just over 4 then as the engine gets hot drops around to under 2, at 3k revs that is.
Mine reads just below the quater mark when idleing hot. checked mine with the other N/A's at the last meet cos i was worried with it reading so low. seems they are all the same.
Peter
Most probably down to a faulty sender unit.....
.....it's a common fault; but the Nissan part is quite expensive for what it is!
Richard:cool3:
^^^^As above, the gauge often gets blamed, but after nearly 20years it is the sender unit that starts to fail.
Changing it cures the problem and makes the gauge read fairly accurately. A new sender costs around £85, but is easy to change.
mne reads exactly the same mate,puts the poopers up ya dont it,mine aint blown yet though lol
