I'm having brake judder when I brake that I
Though was wrapped disks but I have now noticed that my
Tires are wearing on the inside!! What part of the suspension is worn?
I have poly bushes the tension arm all the rest is
Stock on 100k miles
Any help greatly appreciated
Camber arms, have you got 18" Alloys on? Bigger wheels throws the camber out, It has happened to me.
Yep got the 18 on had them for years never used to have tyre wear must be worn, are they the upper arm with 4 bushes in them, my lower arm ball joint is slightly loose no play just easy to move about
Yeah could be the top camber arm or the front tenstion rod are common for failing to
Ah well i will have to update the old suspension i think ££££ will try the camber arms
Pete has some camber arms for sale.
For the front tention rod its only about £30 for some poly bushes, im sure Dan can get hold of them. :)
You should be able to see any play in these before you start spending.
