JaiKai Black Zed Project
Just bought a 1996 Twin T Auto - Series 4 in Black.
Its currently got a cloth interior and a badly fitted veilside kit which I plan
to remove and sell on shortly.
Using my other 1991 NA i'm planning as using that as a donor car and swap
over all the goodies i like on that.
Let the games begin
  • Replies 108
  • Views 6.3k
Getting a respray next month - which colour should i go for ? 29 members have voted
  1. 1. Getting a respray next month - which colour should i go for ?
    • Metalic Purple
      17%
    • Black
      68%
    • Silver
      6%
    • None of the above
      6%
New water hose finally arrived on friday, managed to order the wrong one
last week so i'm now a week behind where i want to be with getting the
zed back on the road.
After doing a plennum water bypass I believe theres only two water pipes
that i need to connect together to complete the circuit.
These are pictures below, now if anybody thinks this is wrong please PM me.
After confirmination that I can safely and carefully split the loom i did
exactly that today, with the help of a fresh stanley blade I scored the
outer sheeth of the loom and peeled all the black sticky tape off.
Also marked each cable to ensure i didn't put things back in the wrong
place.
Before making and taping up the new shape loom i first done a test fit
of the plenum to make sure all the cables are not obscured in someway.
Heres a pic of the new wired loom in shiny yellow tape :
Not the best pic as its fairly dark outside but after I tidied up the loom
and all the connectors I refitted the plennum with its new gasket.
Apart from the cable loom at the far right i've managed to tuck and hide most of the connectors that were in there oem positions.
First thing in the morning weather dependant i'll drain the coolant and fit the
hard pipes i got a few weeks ago.
Was out working on the zed for a few hours this morning and I managed to get
everything back together properly (i hope) and start her up for the first time in
over a month.
Done a precheck for everthing on the plennum then at 6pm i reconnected the
battery and gave the key a turn.
Took three attempts to start her - most likely due to no fuel in the pipes but
after the third turn she started !
Quickly followed by disaster !!
One of the clips on the fuel line on the plennum wasn't tight enough and a 4ft
jet of fuel sprayed upwards all over the car. I turned the ignition off grabbed a
towl to soak up the visable fuel leak and tightened the jubilee clip.
Giving 15 minutes to get rid of the fuel vapour surrounding the car i tried on the
ignition once again - this time with a hissing noice that a traced to a damaged
pipe at the back of the plennum.
So engine rebuild is 90% succesfull and all I need to do is buy some new pipes.
No pics this time as it was like pitch black but i'll take some in the morning.
Was up early this morning and took a shot of the engine as is now !
Still need to get some new pipes so the pipe you see at the back and
right side is tempory !
So heres a before shot :
and heres the new look shot :
Also made a wee video which i'll put up shortly !
Need to change those red pipes too as there causing a vacuum leak
Which you can hear in the video which i'll post.
Looking the dogs danglies mate, very nice.
The pipe on the rear of the balance bar to the iav, without looking at mine, does it not reduce at one end to the balance bar, that might be a part of the leak.
  • 1 month later...
Right its guage time and i'm going all digital !
I've had iridium drift guages from the zcentre for some time now and wanted
to go all out and get some more so got myself 6 in total now !
Starting with the top cluster : Oil Pressure - Air Fuel - Turbo Boost
Bottom cluster we have : Oil Temp - Volt - Water Temp
Heres a pic of the top cluster :
And the two together :
Not sure when i'll get these fitted but hopefully very shortly,
Hardest bit and i'd say scarest bit would be cutting a hole in my dash.
Going to have a few switches below in a row so that i can turn the
whole lot off and for swapping signal on the air/fuel guage.
  • 1 month later...
Lots getting done this week and next, first off the zeds in the body shop getting an
overhaul; new skirts, door fillers, 99 spec spoiler and nose panel courtesy of car.mad
and also a set of vented wings from the zcentre.
Then next week the zeds booked into another garage of my mates to get my meisters
fitted.
Just like to say thanks to car.mad for getting the skirts out to me soo quick - cheers.
They arrived this morning and we quickly done a test fit and must say looking good so far !
I'll be nipping in each day to take more pics and will update them here shortly.
More pics time !
Cars still in the workshop, delays again due to faulty lighting !
The zed was worked on for long as possable in the dark and even at one point we
used the headlights of another car to light up the garage.
The tailgates nearly done and the 99 spec spoiler will be test fitted tomorrow as soon
as everything drys properly.
Getting there !
I say - we are looking smooth !
Fitted the drivers side wing yesterday too and had a wee issue of the middle vent
near the door pulling in to much and it caused the profile of the wing to be shallower
than the actual door; simple fix was to glue a bluck of wood to the interior of the
the wing which pushed it out a bit and also it reinforced it making it more sturdy.
Lastly we have the new nose panel which i meshed up on saturday
Looking good mate, Tell him to trim the fillers like i said in the pm before he sprays them properly. with those skirts the top line will be out slightly .
We test fitted them and it looks ok without being trimmed !
What part needs trimmed and why ?
On a test fit the door closes perfectly and the fillers dont rub anywhere.
Ah no thats fine if they fit then they fit.
Just on some skirts the top line sits a little higher than the skirts if that makes sence.
Keep the pics comming :thumbup:
Actually dont fit, lol
Was told they fitted by the fitter; but then had to trim them after they
were glued to the door, hes gonna back fill any gaps underneath to seal
it all but if i have any problems i'll likely need another set to do it again !
Why is it people just dont listen as i did tell him they would have to be trimmed !
