connector green s**t removal
What the best substance to remove all the green corrosion from the conectors, some are really bad like injector plugs?
cheers
James
I used BCE - Brake, Clutch & Electrical cleaner and a small flatblade screw driver to scrape it off.
im just in the process of going through mine . small emery boards are good for the males. gonna give the vinegar trick a go aswell now .
electrical cleaner spray - trouble is if it is really bad it will corrode the wiring too at the rear of the connector & need new connectors & wires soldering in as a lasting repair.
I tried allsorts of cleaning+ sprays.The best thing is a new connector soldered on + the bit it goes on thoroghly cleaned up,The difference in the way a zed will run after is shocking.
