no spark any ideas?
clean the connectors up on the PTU itself, and both plugs that go into it.... you may find it has green gunk on it, years of corrosion, i used a nail file (emery board tye thingy) but a small file or some folded sandpaper will do it....
Pat seems OK car is now trying to start but seems to not be getting enough fuel how do you check the injectors
Are you starting on the AEM? Have you successfully configured your CAS (ie sync'ed timing)
To check the injectors, turn the engine over and with a long screwdriver, place the blade end next to the injector on the block and put your ear to the other end. You should hear a prominent rapid clicking.
