pcd problem
im running on 8.5 et38 and 9.5 et35 deep dish wheels and my zx is super loward so rear wheel is all most closed to the wheel arch and running on 245/45/18 tyre , i just bought some dish wheels from japan without thinking !! will they fit on my car they are Front 18 x 9.0J offset +25mm
Rear 18 x 10.0J offset +26mm so any help will they fit on my zx???
According to the wheel offset calculator I've used the new wheels are going to stick out an extra 15mm!! http://www.1010tires.com/WheelOffsetCalculator.asp
Are you sure the new rears are ET26?? Cos unfortunately looking at your existing picture they are not going to fit. The arch is going to be sat on the tyre when you take your car off the jack.
Even if you had stock suspension the tyres would stick out too much and may fail an MOT.
Sorry mate. Reconfirm the offsets of the rear wheels.
10" wide @ ET26? You're going to need to do some SERIOUS arch work to get those to fit. Fronts shouldn't be a problem.
BTW, that's offset, not PCD. PCD is the bolt pattern.
They should fit with a very slight lip roll.
The rears will require FAR more than a lip roll! The actual arch itself will require pulling out rather than a lip roll.
really?! I suppose the tyres would come into play, aswell as the suspension drop (camber alterations) If running correct camber and good sized tyres yeah I can def see you needing a pull - but if running a slight stretch and a bit of neg camber I woulda thought a wee roll would suffice - could be wrong. My 9.5 et25's dont come anywhere near the arch on 265's.
It's a +26 on a 10" wheel. That's pretty extreme for the rear of the Z without pulling the arch completely out, even with stretched tyres.
Stretch with too much negative camber wears the tyres at an alarming rate, not to mention far less in terms of contact area.
what you mean by pulling out ?
What do you think I meant? Don't tell me 'that's why you asked'. :rofl: :wack:
