- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Was just finnishing the last few bits so the battery could go in to try and get the car running.
jacked the car up with two hydralic jacks on the middle of the cross member at the front. Firstly using a small one to then get the big one in there to get it high enough to put on ramps.
The front of the car was on concrete with the two rear wheels backed out of my garage onto my shingle drive way. I checked it was central on the cross member as I jacked it up using the the big jack, the back of the car must have slid back on the shingle as it went up and it fell off the jack.
With a loud thump the car slid back off the jack and then fell back down. The jack then was forced into the bottom of the sump making a huge dent about an inch deep before it fell onto the small jack I also had under there!!!.
Cut a long story short I guess its either an engine out job, or all the front suspension will need to come out to replace it. Im just hoping it has not damaged anything inside the sump when it fell onto the jack????.
I am soooooo pissed off right now I cant tell you........
Can you replace the sump with the engine still in the car, if you remove all the suspension and cross member???
Just my luck, only plus side is I never go under the car on a jack at all, even if there are two of them there so at least I was not crushed in the process.
