is there different clutch slave cylinders
Had my car on a ramp just know to check on the oil leaks before i take the engine out, and asked my mate to look at why my clutch bites very low, so low it hardly clears whilst changing gear!
He thinks the slave cylinder looks shorter than usual, i know it has recently been changed but my question is............ is ther different types????
From what I have read they are all the same.
Courtesy Nissan lists 2 "different" ones but they have the same part number ???
I also read somewhere that the Nismo slave for the 240sx is the same,,,but can´t confirm it
Probaly has air in the system trapped.See if it improves when bled.
Thanks guys, just having a coffee and then the task of engine removal begins
