Plastic plugs
Does anyone know where I can get those little plastic plugs that fit on the top of the engine between the plenim.. There is 6 of them wired into the loom. All mine seem to be knackered.
Baz i take it you me coil pack connectors??
If so i know z centre do them, and possibly zedworld, but you need to re solder them in.
Wont be cheap though.
Hi Stu, not sure, they are not the ones on top of the coils, they are the small almost square plugs with 2 pins inside them? trouble is there seems to be loads of them all over with slight variations in the guide slots. Odd really.
They are injector connectors and cost about £8 each I think not looked into it yet but i may need some
if there near the center of the plenum then they will be your injector connections (6 of)
If there near the outer then they will be your coilpack connectors
injector connectors! the nissan ones are expensive but if u go to a scrap yard you can rob some of a ford think the 1.3 ka amongst others fit u just have to shave off the center raised groove on the injector plug ..these have nice wire clip on them too making for a nice conection & easy removal
Hi Stu,
I thought they may be how to do it. They are all knackerd...So I may just get them all done. Its got to improve things such as the occasional missfire. I think I will replace both lots of connectors if I can get them.
I will give Luke a call tomorrow too. Car out now mate so may pop down. PM me when is a good time.
This exactly what i did , searched around a scrappy,s and found that most Ford ones were black ( to replace the injector connectors ) , Vauxhall are yellow ( temp connector on a zed but much better quality !) Volvo were grey (IIAV replacement i think ?? )
Went round cutting off loads of different colours to replace with the correct colours , worked a treat and only cost me £2 :thumbup1::thumbup1:
