Smell of fuel,
Just got mine out after the winter, I have a smell of fuel when I put on the blower. I can also smell it from under the bonet but can not seem to locate it.
Any obvious things I have over looked!
MOst likely the small fuel hoses under the bonnet; around the fuel filter and under the plastic cover in the middle of the "V"
The cold weather causes the rubber to contract a little and the high fuel pressure can result in fuel vapour seeping out of the rubber hose ends.
Worst case scenario means replacing all the rubber hoses; but in most cases, just going round and tightening all the hose clamps will fix the problem!
Richard:ph34r:
That's exactly where mine is leaking... right at the front under the cover and under the accelerator linkage... I can see it's damp around the pipe.... I used a torch to find it....
I nipped it up a bit and it seemed to stop but has come back, got the hose and will replace it as soon as possible.... a bit of a pain to get to..lol...
i had a quite a large leak the other day and it was the hose underneath the regulator on the right. just need nipping up but was a pain to get to
Thanks guys, I have a lighter I will look later.............
haha :sorcerer: :sorcerer:
Nice idea - I'd say you won't have to worry about the fuel leak any more then......:lol:
Sorted....found the leak from the fuel pipe just under the plennim. New bit put in and all good. Had to use a torch as lighter ran out of flint........
