Engine mount bracket
Hi All,
Im hoping you can help me?
Im having alot of trouble with clearence of my engine mount agaist my right side turbo!
Ive ground and cut away so much of the bracket that it will not be strong enough to hold the weight of the engine.
Has anyone else used GD manifolds?
Is there anyother mounts out there i can use? As it dont look like one can be made to fit at the moment unless i miss an surporting bolt out.
Dan
i dont know of any other mount you can use. the only way i know of is to grind away as you have and use an angled pipe straight off the tub.
if there is any other way or different mounts, i would be very interested in knowing about them :)
Is there room to build up the other side of the bracket to put some strenght back into it.
Have you got any pictures.
Paul
there is room on the under side of the leg so, it could be possible to weld some strengtheners on it if you find a decent ally welding shop
If you could let me have a bracket and templates of the strengtheners I will see what I can do.
Paul
Paul
now that could be an answer Dan ;)
Dan, I'll leave the ball in your court then, let me know when you have something you want to send me.
Paul
Thanks for all the replys guys :)
Paul thats a great offer i might have to take you up on that offer ill just have to get some measurements and maybe diagrams of where the turbo sits.
Thanks for the offer ill be in contact
Dan
Silverbullet, if you want to send me a mount and some templates I can do the same for you.
Paul
Hi All,
Dan
There has benn some talk on tt.net regarding the use of FORD TRUCK engine mounts, and I believe JimmyTT had a look at this option some time ago when his engine was out.
I found these links:
http://www.300zx.co.uk/forums/showthread.php?t=105469&highlight=ford+engine+mount
http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=949734
HTH :phone:
Paul
thanks for the offer Paul but, mine are sorted, it was tight but, i got them in ;)
