Dump valve question
Hi all,
I have my blitz bov's on hard pipes but i have noticed that my recircs are also connected.
I have the vacum line coming out of the manifold it then has a y piece which splits, one going to the dump valve and the other going to the recirc.
Would i be able to get rid of the y piece and just have the line going from the manifold straigt to the dump valve? and just leave the old recircs in place... bearing in mind that the diaphram on the old recircs will only allow air out under load... no load no air leak ? so will they be able to stay in situ ?
Thanks.
Dan.
Take out the y connector and remove old recircs and bung the two holes to each one.But use the two vac pipes for your Blitz.
