hello people im new to the 300zx ownership and had a bit of a bad start, iv brought a uk spec tt with manual conversion done and alwas well for a few days untill engine started to knock witch turned out to be bottem end so done and engine swap (found a low miliage lump for 600).when we done the engine swap we noticed that the clutch was on it way out so we thought it was ok when we took it out so itll be ok for alittle longer untill we took it out for its first drive. when on boost or changing gears fast it would grind like the clutch was not fully engaged but if you change gears slowly its fine. so i thought i would just bite the bullet and put a new clutch in as iv done today, but went to drive it home and low and behold the same problem. has anyone got any ideas as to would could be doing this, slow slave cylinder, air in the system or clutch adjustment as its racking my brain now
thanks marc
