As above, been having a few niggles with the lights recently? Firstly the rear near side light would not illuminate, indicators and brakes were ok, so Jeff advised the light module in the boot was faulty, so i replaced it and hey presto it worked!!! But i have just noticed when i press the brake pedal my fogs light up at the front?? Strange
Any suggestions??
Thanks Daz
Drive in reverse LOL.
Bad earth connection I think but a pain to find. You will need a multimeter set on ohms and start testing all the earth points associated with your problem. HTH.
Do you have a rear fog conversion, and if so how and where?
Yes mate, the fog light for the back is in 1 of the reverse light bulb holders!! you`ve got me thinking now?? i have a switch on my centre console that turns it on!! I may have disconnected something when i did my manual conversion?? Do you agree?
Cheers Clint, lol, nice one, will do
Well at least your rear fogs arn't in the brake lights, so that should rule that out. As already said you'll have to do some searching around.
I'm trying to rack my brains as to where it could be as well, but can't see any connection other than Earth from the front OEM fogs to the brake lights :huh: :confused1:
Thanks Dave, To be honest I`ve not even looked yet, it could be something obvious, so i will start in the boot today and work my way around the car till i find something dicky?
Ahh I`ve just realised!! my fogs now illuminate on side lights as they are led driving lamps!!
Arrrrrrr there you go, dicky Earth on the rear lights!
