Brakes - Do R32 GTR FRONT CALIPERS Bolt straight on chaps?
yes, though are the same the 300zx... the R33's are the upraded brembos
Thanks - currently a pair of R33's on ebay at around 50.00 squids...
ive got a set of r33 gts calipers discs etc you can have cheap, they are alloy and an extra 20mm dia than 300 brakes so cheap upgrade :)
the r32 gtr calipers are the same as r33 gts ones. they r33 gtr ones are brembo and 326mm IIRC
you sure about that bud? r32 gtr calipers are identical to the oem 300zx calipers so if the r33 gts ones are the same then it would not make an upgrade. maybe the r33 gts uses bigger discs due to a different mounting point of the caliper on the hub? r33 gtrs are indeed brembos and use 324mm discs as standard...
R23 GTR/ R33 GTS = Same caliper design as Z (and same pads) but fitment for 296mmx32mm disc (instead of the Z32 280mmx30mm).
Im after some rear skyline rear calipers but the upgraded ones compared to the z32, can u post a pic of the calipers & discs plz ruishy? are you sure you didnt mean the r33 gtr calipers as thems are the ones im after, not the gts ones cheers.
its just the fronts i have mate, they are basically the same as the z32 brakes, small differences and all alloy so drastically lighter !
*THREAD HIJACK* How much is cheap? *THREAD HIJACK*
