December 19, 200916 yr Just need to know the name of the plugs i should be using if running higher boost, eventually 21psi. ive got stock plugs at the mo and i think they may be blowing out, as it starts to misfire off boost.
January 3, 201015 yr Author Jimmy mate, at the end of the day it's your car and you driving it. We all think and take on board what we like. I really respect the way you've worked with your zed and your big balls in trying things that others don't/won't :) All i'll say is please remember stock for the US was a 6, for the UK it was a 5, so imo all numbers referred to above, for the UK should be less 1, but that really is my opinion fella. A couple old links for yer but direct info from NGK here in the UK. http://www.300zx.co.uk/forums/showpost.php?p=859825&postcount=4 At the end of the day mate, they hardly an expensive item to buy, so try what you think and change em as you think eh.. Good luck anyways smithy Well i am a bit worried about these plugs now, if they do start fouling then il have to change them, if they dont happy days? i do like being overkill with safety but maybe it is too cold, has anyone used these with problems? I have searched the uk forum and i havent found anyone running the 7's...... or even anyone running them with any problems so its hard to determine if they would give out any problems, theres only one way to find out eh? I appreciate your replys and help smithy very informative as always, maybe you should have posted when i created the thread, it may have affected the outcome lol :( never mind........
