In memory of Mandy
stereo amp in swb
looking to instal an amp in my swb 300. would prefer it hidden
other than on the shelf over the fuel tank with another shelf over the top where is a good place to hide an amp?
[sIGPIC][/sIGPIC]
dont think theres much space anywhere else tbh.
dont forget you are suppost to allow air to get at the amp
Since your a wee short-arse (:tongue:)
Couldnt you mount it behind the drivers / passenger seat?
possibly, could also use it as a heated booster seat :p
[sIGPIC][/sIGPIC]
hahahaaha poor ol ian you can't help being stumpy!
with an answer to your question tho how big is your amp?
behind the passenger side rear seat panel there is enough room to hide a medium sized amp with a bit of ingenious fixing points.
hmm, got various different amps i can use. will look there tomorow. asume i just need to avoid screwing it to the fuel tank :)
[sIGPIC][/sIGPIC]
Just put mine on the wooden bored next to the ecu, then put to metal strips to stop people kicking it then covered over with the floor carpet. Would never know its there
If you want pics please ask
take off the plastic cover on the passenger side the one under the rear quater window and you will see how much room there is behind there
Mine are on the pannel behind the passenger seat, you can only see them when the seat is levered forward
thanks for all the suggestions
next thing is, how to stop the sub sliding around in the boot......
[sIGPIC][/sIGPIC]
Although you said you would prefer the amp out of sight I found the shelf above the fuel tank the ideal place for my Blaupunkt active sub - not overly loud or boomy but you know it's there:)
The cables to the amp come through the plastic trim that normally goes around the seat tilt handle:)
There is also blue illumination behind the "Apache" logo.........
easy put velcro (the self adhesve stuff ) under the box and stick it to the carpet!
