How much is my car worth
OK.....This misfire problem is naffing me off now, and I need a reliable car. So thinking of selling the Z as is and buying another once I get my feet under the table with my new job.
Basically the car is mechanically sound apart from the misfire. This only happens due to heat soak. ie the car has been running for a while (will go all day without a problem). It only occurs once the engine is switched off and the car has been left for 30 minutes or so.
On restarting the car misfires, this then goes away after a while.
Bodywork wise, it needs the roof panel in front of the targas sorting (been quoted £180 to get it done)
the N/S wing needs attention as it has been filled (badly) by the previous owner
the spoiler has the usual problem, nothing major but it's been touched up with a different colour red.
the interior is in very good condition with no rips or any major wear. in fact i would say it's excellent condition.
Its a manual N/A series 2.
I've changed the PTU, Coil pack, Injector Connector trying to solve the problem
Someone with more knowledge than me should be able to sort it, but i haven't got the money or time to throw at it anymore.
I can't break it as haven't got the room...or the Knowledge...lol
It now has an aftermarket stereo with bluetooth, and clear side indicators.
There is a bad amount of over spray there. plus the missfire i would say around £600-£800 for an N/A :(
Have you taken it to any garages? hard to suggest where given that your location as between 2 plump thighs :)
smithy
smithy
lol....I'm in Durham
In that case, i assume you been to andy duffs place?
smithy
smithy
I haven't. where is he based?
Soz mate am not too sure, all i know is he's somewhere up in your direction. If yer didn't mind the drive, i would always reccommend Zedworld in tamworth.
Speciailse in sorting those niggly problems zeds have, amongst other work of course...
smithy
the miss fire might be down to faulty injector plugs.common fault easliy sorted.cost me £85 and 2 hours of my time fitting new ones
Don't be selling it mate! Get it to Zedworld and let em give it the once over! ;) :)
I thought Duffer was in Preston.
Ivan
Rotherham bud
