air leak check
hello every1
done air leak check and had a couple which i sorted
now it leaks a little from dippstick is this normal
thankyou
Don't think so mate sounds like the rings are knackered, someone with a bit more know how will be able to tell you.
get in contact with Jimmer
i bloody hope not, lol
hes name aint on the bottom of the page so wait to he comes on and ask him
thanks 4 reply mate
mine does this mate.
should be normal as you are pressurising the intake, there are breather pipes which go direct to the cam cover, which should vent to the sump which obviously connects to the dip stick
i hope
Aye yes I get this when doing a boost leak test. I shove a bit of tube with the end capped off over the dipstick hole when I do it.
