garage called today, emmissions are out because of pipes at the back of engine conencted wrong/going to nowhere
only thing i can think of is the EGR. (unless anyone thinks anything else)
now the EGR solenoid is removed from the car, and the take-off on the side of the engine is blocked off.
but the EGR valve itself is still there on the back of the engine.
will this casue a vacuum leak? or will it be re-dundant as there is no solenoid/pipe from the engine going to it
should be fine mate.
i would check the idle valves, i had a leak from mine and the hoses connecting to the plenum
na idle valve is fine.
as long as the EGR is fine left alone sill left there,
wonder what pipes the garage are refering to then? they defo said thers things disconected/attached wrong?
il have to have a chat on the weekend
