September 20, 200917 yr Can I run Vacuum lines... ...from the recirc - direct to the balance bar - rather than to the strange swan neck vacuum connector on the passenger side of the plenum? The drivers side goes direct to the balance bar - so I assume the other side should be fine doing the same. No EGR, no PRVR, no AIV, no Carbon canister - so I have nipples spare! :rofl:
September 20, 200917 yr if you wana keep pipes nice and simple/clean, you could just T piece from the other re-circ vacuum, so the pipe be hiden under the bumper/nose panel
September 22, 200917 yr Author Good idea - but I think I will stick with direct A to B connections where possible matey. Thanks again.
