restricted
my car is jap import and has been restricted (speed wise), is this normal?
and how can i get it de- restricted ?
Yes, You need to get a UK speedo or get a converter chip to get it into MPH and to deristrict it at the the same time
If you're in Coventry I suggest you speak to Jeff at Zedworld for advice as to the best
Hope this helps
Tony
cool another thing to add to my list for when i visit jeff :D - my speedo has been converted and my speed is in mph but for some reason it will not allow me over a certain speed- ( i wont say what speed- as i will probably be asked by funky si - 'why do i need to go that fast' which will make me feel bad and not do it :D)
if you do the mph conversion that remvoes the 110 restriction.
the ECU is still restricted to 155mph tho.
best way is to get a chip to remove it, you can also up the boost etc then aswel.
any idea where i can get the chip from and how easy is it to change or do i have to get a professional to do it??
you need to get it soldered in. its quite small so yea usually a pro does it for you.
unless you are good with small solderes.
there are people on here which do chips, John dixon, and DTA motorsport do them, do a search :)
about £100 :)
ECU will restircit it! When plugging into to Console just set the max speed to 240mph :) Then you can try and reach your new Maximum :)
