oil leak from turbo
Hi.
I have gained a leak, seems to be coming from the joint between where intake joins onto the drivers side turbo. the part thats bolted on, that the rubber connection goes to i mean.
Is there a seal/gasket under there?
Car does not smoke at any time, boosts well + doesnt make any noises from either turbo.
smokes under the bonnet when it drips on turbo.
Any ideas?
the oil is probably not coming from the turbo or intake (as then the car would smoke very bad)
It's more likely to be a leak from the cam cover, which is a plenum off job to fix.
