protoj ·
I've been trying to help a mate with his bm, trouble is the last keeper pulled all the relays out+ i cant find any info on what goes where.
By trial+ error it now runs,but with only speedo, rev counter is erratic+ fuel gauge, temp gauge + miles are not working.
Any ideas??
