Octane boost
Anyone used or using one of these in line cartridge type octane boosters ? Do they work or it it a load of rubbish?
Unnecessary waste of money.
ย
Just stick to high octane fuel (V-power, BP Ultimate..etc)
Cheers, will be giving it a swerve then.But was always told that imports are set to run on 100 RON and I have been using the shell optimax plus a octane boost additive, should I just not use the additve and just run on the fuel alone?
ย
V-power or BP Ultimate etc will be fine on their own.....
ย
Richard:)
I have read on (i think) "Robo's info" that "Toulene" is one of the best additives to up the octane rating if added in the correct percentage. Now, i believe that toulene is a non-abrasive cleaner but works well to up the RON rating. I have this, in abundance where i work, should i use it? Is it ok to use? What do you all think?
ย
Al.
imports will run fine on 95, there are loads on here that do it and never have any probs, i choose to run on 97 for no reason whatsoever apart from that im a petrol snob, whatever you do dont travel 20 miles out of your way to put in v power, it will run fine without it.
If you have chipped and boosted it you may need 97 as it can cause det and will kick into safety mode.
