as above. with the ignition on, even with the wiper switch off. the only thing the switch will do is make them go faster if you turn it to the fastest setting. read threads about this but non seem to come to a conclusion. have tried a new relay, had the switch apart, which all apears fine. took the top off the motor were the plastic cogs and sensor thing is. cant see anything broke or corroded. i can get hold of a new motor but its of a z of a similar age and mileage (94 and 145k miles) so wont that be ready for giving up aswel? any advice or anyone with a newer motor would be appreciated. cheers, danny
