Revs move when i select a gear
When i am in neutral my rev's are a little under 1000rpm, but when i put her in gear with the clutch pressed in they increase very slightly, is this normal, or does it mean throwing more money at her. cheers, Dom
How does this work then :confused:
I only noticed it on mine the other week :rofl:
Neutral switch in gear box goes closed circuit when a gear is slected.
Jeff TT
so there is a switch then in the box.
Whats the point in this function??
Yes both the autobox and manual box have switches that are wired into the engine ecu.
The idea is to help prevent stalling when pulling away, so the timing advances slightly when either a gear is selected or as in the case of an auto drive is selected, many of the switches in manuals do not work now and can be the cause of tickover and pulling away issues like hesitation.
Jeff TT
