Clutch not working
I have bleed the clutch on the cylinder by the gearbox and the one in the engine bay but still can't get the car in gear. Do I need to keep bleeding the system as air might be working it's way up the system? I had no clutch booster cylinder when the manual conversion was done, just the resevoir and cylinder on the gear box and bleed pipe in the engine bay. Any ideas?
Bleed them again and rocked the car in gear in case it was stuck. One of them worked as I know have gears!!
have you got a full pedal? (does it come up all the way i mean)
or just half way...
there is something by the HICAS to do with it,
what i did, was keep a bit of wood going from the steering wheel to the pedal,
so the pedal was presst in fully.
left it for 2 days, took the wood off, then it was fine! :)
