Refurbished my wheels
Had some time off this week so I have been refurbing my front rims, this is the first one just needs bolting back together, should Finish the other one tomorrow.
Paul
  • Replies 35
  • Views 960
How I did mine,
First I rubbed the rim down with a fine scotch bright,this highlighted any pitting and dents.
I then welded the parts of the rim which were to deep to be sanded out and then I ground these bits down with a fine grinding disc 120 grit, I only used 120 grit on the outer edge of the rim after I used 120 & 240 grit on a dual orbital sander just to reshape the edge of the rim.
After this I started with 240 wet and dry and all grades in between up to 1200, I think it was 6, and finished of with autosol but will be trying what Si and bigman have recommended.
If you rims are not to bad then start with a higher number grit.
Also make sure you have removed all the sanding marks from the previous paper or the results will be very poor.
Good Luck Paul
How I did mine,
Good Luck Paul
Thank's mate that is great.:D
Good Luck Paul
Thats what i did then when it rain they went crap again :(
