Where's the best place to route a...
...vacuum feed pipe (6mm) from my mechanical boost gauge to the balance bar? I know a lot of people have rooted wires through the bonnet release wire grommet on the bulkhead, but I didn't want to put the vacuum pipe through there as it looks a bit tight. With oil and water wires already going through there, I'm worried it may kink the pipe?
Is there another way I can feed this pipe?
Cheers for any help
Dave
Mine goes down the passenger side wing, through the rubber grommet, past the ECU and to my center console :)
that's a good idea! Cheers mate :duffer:
Np mate!
Its very simple to install, just remove the wheel and the wheel lining and it will be very simple :)
Np mate!
I'll do that tomorrow. cheers
ive got all my wires through there,
oil temp, oil press, boost, and the amplifier power wire,
all work fine :smw:
