- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hello All
Â
Right i'll try to explain this as best as i can, having just purchased a HID kit, i thought i'd fit them today, no probs with the passy side works ok, did the drivers side, no good, the light flickers but doesnt stay on, so pluged the drivers side ballast and bulb into the passy side worked ok. Right so then i disconnected both HID and pluged the normal bulbs back in. the passy side works ok tested with meter 12volts no probs, now the drivers side has 12v at the clip but as soon as you plug the bulb in you only get 3 volts and for some reason both the main beams come on all be it very very dim, so somehow they are robbing the power from the drivers side dipped beam, but it only occurs when i plug the drivers side dipped beam bulb in, the passy side has no issues. any ideas coz its really doing my head in, i cant understand why as soon as you plug the bulb in the volts drop to 3 and the bloody main beams come on, even though the stick position is set to off. anyone know where to look????
